automation error
Posted: Fri Aug 24, 2012 11:59 am
by yuval
Im trying to open tm1p.xla as usual and "automation error" message pop up, tried to use ibm solutions like register mscomctl.ocx
but with no success, does anyone know this error?
thanks
Re: automation error
Posted: Fri Aug 24, 2012 12:45 pm
by moby91
What happens when you execute the steps outlined by the IBM Technote 1608271 after you started the DOS Shell (cmd.exe) using the "Run as admin" option ?
http://www-01.ibm.com/support/docview.w ... wg21608271
Unable to launch TM1 Perspectives: Microsoft Visual Basic Automation Error Unspecified Error
Posted: Tue Aug 28, 2012 2:00 pm
by yuval
it works, I guess I tried to register the file in the wrong path
Posted: Fri Aug 31, 2012 1:29 pm
by tcasey
I'm getting this same error on my work laptop (but not on my work desktop, nor is anybody else at work getting this error).
I followed the steps at below link for both Excel 2003 and 2007 (I run both on my work laptop and desktop):
http://www-01.ibm.com/support/docview.w ... wg21438688
These steps complete successfully, but on reboot the problem still persists.
Also on the laptop, Architect won't run normally - it crashes on displaying cube views.
I've uninstalled/reinstalled TM1 on the laptop and it still persists.
Both desktop & laptop run Windows XP Pro Version 2002 SP3
Anybody else having this problem/found a solution?
...Tom
Posted: Tue Sep 04, 2012 1:28 pm
by tcasey
Update : Solution Found...
This morning I got the error on my desktop as well after Windows Updates were automatically installed on my computer. Through the advice of our tech guy I followed the instructions for Windows 2007 and Excel 2007 (even though I am running Windows XP and Excel 2003/2007):
Per IBM Tech Note:
Resolving the problem
Unregister and re-register the mscomctl.ocx file.
For 64 bit machines:
regsvr32 /u C:\Windows\SysWOW64\mscomctl.ocx
regsvr32 C:\Windows\SysWOW64\mscomctl.ocx
For 32 bit machines:
regsvr32 /u C:\Windows\System32\mscomctl.ocx
regsvr32 C:\Windows\System32\mscomctl.ocx
Following the 32-bit instructions put me back in business.
...Tom
