Please find the attachment for the error mentioned in the topic.
Help me in this, i am getting this error when I tried to open the excel file in TM1 web application folder.
The version of TM1 is 9.5 and excel is 2010.
tm1xl.ocx error
charan
- OLAP Product: cognos tm1
- Version: 9.5
tm1xl.ocx error
- tm1xl.PNG (24.27 KiB) Viewed 10355 times
charan
- Version: 9.5
Re: tm1xl.ocx error
Any help please
charan
- Version: 9.5
Re: tm1xl.ocx error
please give me some information
asutcliffe
- Version: 9.4.1 - 10.1
Re: tm1xl.ocx error
Have you done a "search online using the error code as a search term"?
charan
- Version: 9.5
Re: tm1xl.ocx error
yes, i tried it but still no luck
asutcliffe
Re: tm1xl.ocx error
No luck with what? Apologies if I seem a bit unhelpful but it's not clear to me what you have and haven't tried. If you search for that error code, you will find a potential solution. I'm just trying to help you help yourself.charan wrote:yes, i tried it but still no luck
Malcolm MacDonnell
Re: tm1xl.ocx error
Did you select "Run as Administrator" to open the command shell?
Mal
Mal
charan
- Version: 9.5
Re: tm1xl.ocx error
yes, I tried with that option.
Gregor Koch
- Version: 9.0 and up
- Excel Version: 2007 and up
Re: tm1xl.ocx error
So you have searched this forum on the ocx file and have tried everything from those posts and you also have searched the web on the regsvr32 error code?
And you have tried this?
http://www-01.ibm.com/support/docview.w ... wg21458748
Good luck, but you might want to call IBM support.
Obviously you don't get the error you are showing in your screenshot when you are doing the above - you get it when you manually try an register the ocx. And this is where it starts... first you cannot properly specify your problem (might want to include the full TM1 version and also the OS) and what you have tried to resolve it and then you post two follow ups that pump up your OP.charan wrote: i am getting this error when I tried to open the excel file in TM1 web application folder.
