Copy and Paste a range of cells into DBRW
Posted: Wed Feb 25, 2009 10:46 pm
by Rashed
Hi guys....not sure if this has already been posted before. Is there any way to copy and paste a range of cells into a DBRW range of cells? Thanks in advance.
Re: Copy and Paste a range of cells into DBRW
Posted: Wed Feb 25, 2009 10:55 pm
by John Hobson
You need to write a little bit of VBA code that
* captures the copy value
* loops through the target range
* retrieves the element co-ordinates on a cell by cell basis using the parameters of the DBRW formula
* does a DBS of the copy value using those co-ordinates
* replaces the DBRW formula
* moves to the next cell
It's fairly trivial. ISTR that something has been posted here before that did this.
Edit - perhaps less trivial range to range than cell to range but still quite doable
Posted: Wed Feb 25, 2009 11:09 pm
by paulsimon
Rashed
You can write your own as John suggested. Cubewise do a tool that will do this. The Beachware tool did it a long time ago, but I am not sure if it is still around. Applix bought Beachware a long time ago so I am not sure why this feature never made it in to the product.
Other alternatives are to use the Cube Viewer, TM1 Web or the In-Spreadsheet Browser, neither of which use DBRW. However, the ISB is being dropped after version 9.4.
Paul
Posted: Thu Feb 26, 2009 12:49 am
by Alan Kirk
Rashed wrote:Hi guys....not sure if this has already been posted before. Is there any way to copy and paste a range of cells into a DBRW range of cells? Thanks in advance.
As per John's comment, VBA will do it for you. It's also part of one of the packages put out by SPF (http://www.spfplus.com/), which may be worth looking at if you have the need.
Posted: Thu Feb 26, 2009 1:23 am
by Rashed
Thanks Guys...this forum is awsome!!!!
Posted: Thu Feb 26, 2009 1:45 am
by Alan Kirk
PaulSimon wrote:You can write your own as John suggested. Cubewise do a tool that will do this. The Beachware tool did it a long time ago, but I am not sure if it is still around. Applix bought Beachware a long time ago
I wouldn't say that in front of Johann Potgieter if I were you... not unless you're wearing gridiron padding.
Beachware is what became SPF.
Posted: Thu Feb 26, 2009 7:13 am
by John Hobson
Yes if memory serves me well didn't someone buy the name but forgot to buy the product or something or was it the other way round.
It's a long time ago but there was a funny story there somewhere...
SPF was/is quite a neat tool. (Neat at that UI level that Applix never ever managed to get right or copy properly.)
Posted: Thu Feb 26, 2009 8:44 am
by Steve Rowe
You can also consider using DBS(W) for sending the data in. SInce the source is ordinary excel you can copy and paste to your hearts content then.
