Rebuilding Active Forms using VBA
eddoria
Version: 9.5.2
Excel Version: 2003 and 2010
Post by eddoria »
I need to create a macro which selects a sheet and rebuilds the active form. Is this possible using VBA? We are using Excel 2003 and TM1 9.5.2
Any help with this would be greatly appreciated.
Thanks and regards
Vera Hawkins
BigG
OLAP Product: IBMPA
Version: PA 2.0 Cloud
Re: Rebuilding Active Forms using VBA
Post by BigG »
I think you are after
ActiveSheet.Select
Application.Run "TM1RECALC1"
but if you search the forum you may find some better examples
GG
BigG wrote:I think you are after
ActiveSheet.Select
In fact you would be needing Application.Run "TM1REFRESH" which is the macro to rebuild an active form. TM1RECALC1 recalculates the sheet but it will not trigger rebuilding of the rows of an active form.
