Hi gurus
I did a SavDataAll on my server and then restarted it. When I then log in all my processes/cubes/dims are not shown. I can see then in the TM1Data directory though... How do I get the back in the architect server again?
Br
Peter
Can't see cubes/dims or processes after restart.
Re: Can't see cubes/dims or processes after restart.
Is this a local server TM1 you are running? Do you have the Start Local Server on Startup option checked in Architect. If it is not a local server running on your workstation then the obvious question is did you close Architect and restart it after the server restart? If that is affirmative, can you log in with the Admin ID and see if the objects are still there? If they are, and your normal ID cannot see them then your security may be messed up. In this case you may have to redo it, or at least do some research to find out what you can and can't see and correct. Sorry, wish I could give you more.
A.Pete
- OLAP Product: TM1 , transformer
- Version: 9.5 + 10.1 + 10.2 + 10.2.1
- Excel Version: 2010 + 2008
Well I probably did it the wrong way since i went in to the services and restarted the server from there. Then i closed architecht and opened it again and i still cant see anything. I was using the admin account all the time..tomok wrote:The obvious question is did you close Architect and restart it after the server restart? If that is affirmative, can you log in with the Admin ID and see if the objects are still there? If they are, and your normal ID cannot see them then your security may be messed up. In this case you may have to redo it, or at least do some research to find out what you can and can't see and correct. Sorry, wish I could give you more.
BigG
- OLAP Product: IBMPA
- Version: PA 2.0 Cloud
can you see the cubes etc in Tm1web?
Also check Architect> options > admin host ... make sure its pointtong to the server...try with full domain name?
GG
A.Pete
BigG wrote:can you see the cubes etc in Tm1web?
Thanks for the info. Im still not getting the anything. I cant see anything in framwork manager and since architech is installed on the same server i tried localhost and the full domain name but still nothing.
br
Peter
A.Pete
Pheww, got them back. Had to restart teh server a couple of times and all of a sudden they were in there again!!
Thanks for you help though!!
Br
Peter
Br
Peter
