Excel 2010 Crash DBRW and DBSW at same time
Thijs.Spruijt
Version: 9.5.2
Post by Thijs.Spruijt »
Dear All,
We have build an active form. On top of that I created a VB macro which in principle
-Copy the DBRW part
-Past below in the sheet (first free row) as Value.
-Create DBSW formula's so users can copy and past.
Now in some exectional cases Excel Crashes without any reason.
I put off automatical recalc and disabled the recalc before save.
So my question. If in the Active form I have on the same combination a DBRW function and somewhere else in the sheet a DBSW function, could that cause problems? Which takes priority.
Any sugestion will be helpfull.
Thijs Spruijt
sander
OLAP Product: tm1
Re: Excel 2010 Crash DBRW and DBSW at same time
Post by sander »
Dou you use rdp, or is it on your desktop/laptop?
sander
OLAP Product: tm1
Post by sander »
If it is RDP uncheck 'clipboard' on the tab 'Local Resources' before you start it, that helped me
Thijs.Spruijt
Version: 9.5.2
We use Excel via Citrix so no RDP
This isn't likely related to your crashing but it would be exceedingly bad design to be DBRWing and DBSWing into the same area(s) in the cube in the same spreadsheet. It's going to be almost impossible to predict with regularity how the precedence is going to worl. That's because DBRW's are bundled in network packets while the DBSW will have one formula per packet.
Thijs.Spruijt
Version: 9.5.2
Thanks for your reply. I will write some more VB that will clear out the DBRW formula's.So I will only have DBSW.
Post by David Usherwood »
@tomok, I recall being told by the IBM engineers at Black Belt in 2010 that if you used a VIEW() function for your DBSWs then you got the Stargate speedup. Can't say I have done a formal test myself though.
