ISSUE IN FEEDING FROM CONSOLIDATION TO N LEVEL ELEMENT
Jodha
Version: 9.5.2 10.1 10.2
Excel Version: 2007 2010 SP1
Post by Jodha »
i have feeders issue of the following rule
Skipcheck;
[x,y] = N:IF(Z<>0 ,1-Z,1);
Feeders
Z => DB(IF(z <>0 ,SameCube, '') ,!dim1...!dim4,X,Y)
here "Z" is consolidated element with 13 chidrens when this consolidation is non -zero rule works fine
but when Consolidation has zero values then i have feeding issue as we need to have atleast one child to have a value to feed from C level to N level
so i created a dumy N level elemnt "No Value " under Z Consolidation as used this for rule
[No value] =1; and included feedeer statement
[No value] => Z;
my final rule look like this
Skipcheck;
[No value] =1;
Feeders;
[No value] => Z;
what i need to modify in feeder statement to make this rule work for all cases.
Re: ISSUE IN FEEDING FROM CONSOLIDATION TO N LEVEL ELEMENT
Jodha wrote:[x,y] = N:IF(Z<>0 ,1-Z,1);
With the above code [x,y] will pretty much always have a value, unless Z is quite often 1?
In the event that Z is often 1 and therefore [x,y] is often 0 then a conditional feeder could make sense BUT if it always has a value then you may as well just always feed it from something that has a value.
I bolded something above due to the fact that although [x,y] is derived from Z it doesn't need to be fed from Z so it can be fed from anything with a value.
Jodha
Post by Jodha »
"I bolded something above due to the fact that although [x,y] is derived from Z it doesn't need to be fed from Z so it can be fed from anything with a value. "
i made changes in feeder statement from
to
['NO Value'] => DB(IF(z <>0 ,SameCube, '') ,!dim1...!dim4,X,Y)
because ['No Value'] element has always value 1 and still same problem i cannot values for [X,Y] under Zero Suppression correct me i am missing any thing
Thanks for the replay
Jodha wrote:"I bolded something above due to the fact that although [x,y] is derived from Z it doesn't need to be fed from Z so it can be fed from anything with a value. "
to
['No Value'] is also rule derived so you will need to feed those elements in order to be able to feed from them. An easier method could be to build a 2d control cube and have a 1 in there to feed from.
HTH
Jodha
Post by Jodha »
thanks for the fast replay
is there any other way to achieve this apart from build 2d cube
BigG
OLAP Product: IBMPA
Version: PA 2.0 Cloud
Post by BigG »
I am unsure if I am following this correctly, but feeder works when values in children of z (beacause of the condition in the feeder DB(IF(z <>0 >?
It is when z is zero with no values in children you have an issue feeding the other part of the rule - then false output of 1 ? [x,y] = N:IF(Z<>0 ,1-Z,1);
Two options you can try (depending on the problem):
1) hard code 'Z' element into the conditional statement for the feeder, because you are feeding from a consolidated element it needs to be for feeders I believe (as opposed to !Z dimension ref, dont think this works). You may be doing this anyway, but the example is hard to see this
2) create a conditional feeder for the false side of condition in rule? [No value] => DB(IF(z =0 ,SameCube, '') ,!dim1...!dim4,X,Y)
GG
Harvey
Version: TM1 8.3 onwards
Excel Version: 2003 onwards
Post by Harvey »
Jodha wrote:i have feeders issue of the following rule
Maybe I'm being daft here, but when Z does equal 0, then subtracting it from 1 will be 1 in both clauses of your IF statement. Hence, isn't
[x,y] = N: 1 - Z;
functionally the same rule?
However, that doesn't solve your feeling problem!
It's a little difficult to comment on that without understanding what you're trying to achieve. I'd look into feeding from another value for this, or having a dummy value that is always 1 to feed from.
Jodha
Post by Jodha »
Thanks Guys for the Replay's
I created an dummy element and feed that element with a value all time and used this in feeders
your suggestions really helped a lot, this forum rocks.
