Running out of disk space
Posted: Wed Aug 01, 2012 1:03 pm
Hi ,
We are running out of disk space on our server (C: 5Gb free space)
recenlty we delpoyed tm1 components from dev to qa and loaded with current data , then service crashed ,
we took the backup of TM1Server.log and TM1s.Log files and restarted the services.
when we are trying to open cube views ,disk space came to 0 Gb then rebooted the server and checked in the server c:\Windows\PCHealth\ErrorRep\UserDumps
" tm1sd.exe.20120801-182508-00.hdmp" files are created, these files are keep on occupying the space on the C disk runs out of space even cube view closed.
Event log also throwing the errors " faulting application tm1sd.exe version 9.5.20000.faulting module tm1sd.exe version 9.5.20000.faulting address tm1sd.exe version 9.5.20000.
we tried to load the data in dev ,everything is good.
can anyone help to resolve the issue?
1.why the service is crashing after the load the data into cube ?
2.Is there any way we can restrict this dump file generation ?
Thanks & Regards
Guntupalli
Thanks & Regards
Guntupalli
