Percent-Value simply a Copy of another cell?
Posted: Tue Jul 24, 2012 7:51 pm
by schlemiel29
I created an active form in Excel 2007. It works fine and shows correct values, regardless the formating as number or percent value.
If I publish this in web all cells previosly shown as percent show same value as a column to the right (lets name it "A"). First I thought it depends on the column width, but even if I use the same size as A it shows the values of A. Before I throw the entire report away and start from the very beginning, does somebody has a tip to repair this "bug"?
The name of one element is "%". Is there a problem in using %-Signs in element names in web?? If I create a view and from this an active form, publish this one to the web, it shows correct values. Seems to be more complicated to find the source of this strange behaivor. Any hints?
Best regards
Dirk
Re: Percent-Value simply a Copy of another cell?
Posted: Wed Aug 22, 2012 2:38 pm
by Steve Rowe
Admin Bump
Please post in the correct forum, the Bugs forum is only for bugs that have been reported to IBM .
