What is the % sign used for in TM1 rules? I see this used in code I inherited. It doesn't look like it is for division as front and back slashes are used.
Thanks.
% Sign in TM1 Rules?
Re: % Sign in TM1 Rules?
It's in the docs - % is 'or' in logic tests.
David has given you the answer. Granted it's not always easy to search for individual operators in the documentation, which is why a link to the "Rules Syntax" chapter is one of the "Frequently Referenced Sections" found in the FAQ.youngjedi wrote:What is the % sign used for in TM1 rules? I see this used in code I inherited. It doesn't look like it is for division as front and back slashes are used.
This is used as or statement.
