Cognos Express Licensing
Posted: Fri Jul 13, 2012 8:02 am
Anyone…
I need some help getting to the bottom of the IBM Cognos Licensing agreement for Cognos Express,
I have Cognos Express installed on a Single server install, completely standalone setup. I've created additional Instances of Cognos Servers (Services) i.e. I have CMDX plus a couple of others.
IBM support are stating that this is not supported as it breaks the licensing agreement.
The only information I can find on this is in the release notes.
I quote:
Release Notes
IBM Cognos Express
Version 9.5.0
IBM Cognos Express Does Not Support Additional Instances of TM1 Servers Other Than CXMD Server
Additional TM1® server instances, beyond the installed CXMD server, are not supported in the Manager console.
If you attempt to restart IBM ® Cognos ® Express ® from the Manager console (which restarts IBM Cognos Analytic Server as part of the process), the restart of ICAS will fail if new TM1 server instances have been created in addition to the CXMD server that is provided with IBM Cognos Express.
The title "Cognos Express Does Not Support Additional Instances of TM1 Servers Other Than CXMD Server" However, the text is referring to the admin console.
To further confuse matters, in the Express Installation and Configuration guide under the Xcelerator Operations Guide 9.5, I found :-
Xcelerator Operations Guide 9.5.0
Installing a Server to Run as a Windows Service ICASTo install a ICAS server to run as a Windows service, use the following command line format:
tm1sd.exe -install parameters
http://publib.boulder.ibm.com/infocente ... ssues.html
Stating how to create additional servers.
I'm confused !!!!
Anyone have any clue ?
I quote:
Release Notes
IBM Cognos Express
Version 9.5.0
I'm confused !!!!
