We have published packages from TM1 9.5.2 to BI 10.1. After adding an additional user group and assigned the appropriate access in both TM1 and BI, the user gets the above error when running the (report studio) report. We have triple-checked the access for this new group (which is set-up exactly as already existing groups) and tried re-publishing the packages, without results.
If anyone else has experienced the same, I would highly appreciate a hint (didn't find any search results pointing to a solution).
Internal PCMDDS-error in tm1odpCube.cpp: 1534
- OLAP Product: TM1, Transformer
- Version: TM1 9.5
Re: Internal PCMDDS-error in tm1odpCube.cpp: 1534
I know it's been a while, but have you found a solution for this issue?
- Michel Zijlema
- OLAP Product: TM1, PALO
See this post.jaudouig wrote:Hi,
Michel
