I am new to TM1 and getting following errors. Any help will be appreciated...
When I launch http://localhost:8080/pmpsvc (I get the attached error, server name Planning Sample does not populate)
Log Name: Application
Source: tm1sd
Date: 7/6/2012 3:01:14 PM
Event ID: 0
Task Category: None
Level: Error
Keywords: Classic
User: N/A
Computer: CLARITY.ifasfarm
Description:
The description for Event ID 0 from source tm1sd cannot be found. Either the component that raises this event is not installed on your local computer or the installation is corrupted. You can install or repair the component on the local computer.
If the event originated on another computer, the display information had to be saved with the event.
The following information was included with the event:
tm1sd error: 1063
StartServiceCtrlDispatcher failed.
Event Xml:
<Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
<System>
<Provider Name="tm1sd" />
<EventID Qualifiers="0">0</EventID>
<Level>2</Level>
<Task>0</Task>
<Keywords>0x80000000000000</Keywords>
<TimeCreated SystemTime="2012-07-06T22:01:14.000000000Z" />
<EventRecordID>774</EventRecordID>
<Channel>Application</Channel>
<Computer>CLARITY.ifasfarm</Computer>
<Security />
</System>
<EventData>
<Data>tm1sd error: 1063</Data>
<Data>StartServiceCtrlDispatcher failed.</Data>
</EventData>
</Event>
I removed Planning Sample and re-added and now I get this error
Source: tm1sd
Date: 7/6/2012 4:47:31 PM
Event ID: 0
Task Category: None
Level: Error
Keywords: Classic
User: N/A
Description:
tm1sd error: 0
C12) Log file exists. Do you want to recover changes?
Event Xml:
<System>
<Level>2</Level>
<Task>0</Task>
<TimeCreated SystemTime="2012-07-06T23:47:31.000000000Z" />
<EventRecordID>830</EventRecordID>
<Security />
</System>
<EventData>
<Data>tm1sd error: 0</Data>
<Data>C12) Log file exists. Do you want to recover changes?</Data>
</EventData>
</Event>
Contributor Error
- OLAP Product: Cognos
- Version: 9.5
Contributor Error
- TM1 error.docx
- Error Screen Shot
- (41.72 KiB) Downloaded 127 times
- Version: TM1 10.1
- Excel Version: 7
Re: Contributor Error
Can you also attach webapps/pmpsvc/WEB-INF/logs/pmpsvc.log ?
- Version: 9.5
Thank you Mark.
Here are the last few lines from log file
2012-07-06 16:55:59,166 [http-8080-6] ERROR () com.cognos.pmta.api.modelmanagement.ModelManager - Unable to initalize API
com.ibm.cognos.tm1.TM1Exception: Could not load tm1api.dll due to: The specified module could not be found.
at com.ibm.cognos.tm1.API.internalInitialize(Native Method)
at com.ibm.cognos.tm1.API.initialize(API.java:307)
at com.cognos.pmta.api.modelmanagement.ModelManager.<init>(ModelManager.java:129)
at com.cognos.pmta.api.modelmanagement.ModelManager.<init>(ModelManager.java:121)
at com.cognos.pmta.api.modelmanagement.PlanningFactory.getModelManager(PlanningFactory.java:53)
at com.ibm.cognos.pmpsvc.servlet.ConfigServlet.doPost(ConfigServlet.java:88)
at com.ibm.cognos.pmpsvc.servlet.ConfigServlet.doGet(ConfigServlet.java:71)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:617)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:717)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:290)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:233)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:191)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:127)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:102)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:109)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:293)
at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:859)
at org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.process(Http11Protocol.java:602)
at org.apache.tomcat.util.net.JIoEndpoint$Worker.run(JIoEndpoint.java:489)
at java.lang.Thread.run(Unknown Source)
2012-07-06 16:56:01,467 [http-8080-6] ERROR () com.cognos.pmta.api.modelmanagement.ModelManager - Unable to initalize API
2012-07-06 16:56:04,834 [http-8080-2] ERROR () com.cognos.pmta.api.modelmanagement.ModelManager - Unable to initalize API
2012-07-06 16:56:06,566 [http-8080-1] ERROR () com.cognos.pmta.api.modelmanagement.ModelManager - Unable to initalize API
2012-07-06 16:56:09,566 [http-8080-6] ERROR () com.cognos.pmta.api.modelmanagement.ModelManager - Unable to initalize API
2012-07-06 16:56:10,460 [http-8080-1] ERROR () com.cognos.pmta.api.modelmanagement.ModelManager - Unable to initalize API
2012-07-06 16:56:11,304 [http-8080-6] ERROR () com.cognos.pmta.api.modelmanagement.ModelManager - Unable to initalize API
2012-07-06 16:56:17,711 [http-8080-1] ERROR () com.cognos.pmta.api.modelmanagement.ModelManager - Unable to initalize API
2012-07-06 16:57:05,109 [http-8080-1] ERROR () com.cognos.pmta.api.modelmanagement.ModelManager - Unable to initalize API
2012-07-06 16:57:07,817 [http-8080-6] ERROR () com.cognos.pmta.api.modelmanagement.ModelManager - Unable to initalize API
2012-07-06 16:57:08,880 [http-8080-1] ERROR () com.cognos.pmta.api.modelmanagement.ModelManager - Unable to initalize API
2012-07-06 16:59:05,189 [http-8080-1] ERROR () com.cognos.pmta.api.modelmanagement.ModelManager - Unable to initalize API
2012-07-06 16:59:08,640 [http-8080-6] ERROR () com.cognos.pmta.api.modelmanagement.ModelManager - Unable to initalize API
