Hi there,
Is there a way of dealing with null element values in a CSV file when importing in TI?
I have a CSV file with a column that is not always populated as it's not always relevant. The TI process runs but does not import the rows that have a null element - error is : Data Source line (21) Error: Data procedure line (4): Invalid key: Dimension Name: "SubNominal", Element Name (Key): ""
I would like to replace each null with something like "n/a" and have this as an element in the destination dimension, and I want to avoid having to do this in SQL before TI gets the file as this is to be a direct export from the source system.
Can it be done in the prolog section or metadata section with a rule?
I am quite new to TI code - I've had a good trawl round the forum and the TI user guide but I can't find anything specific that doesn't recommend doing it outside of TI.
Steve
Dealing with nulls in TI
asutcliffe
- Version: 9.4.1 - 10.1
Re: Dealing with nulls in TI
Essentially you want an if statement that says when SubNominal is empty, set it to n/a. I think you're using the wizard right? You can achieve this by creating a new process variable and setting the formula to something like:conflax wrote:Hi there,
vSubNominalNew = If(SubNominal @= '', 'n/a', SubNominal);It's well worth looking at how this actually works by reading the code on the advanced tabs.
EvgenyT
- Version: PAL 2.0.8
As asutcliffe posted above you can use IF statement to set variable to n/a. Alternatively if you can skip them all together by using IItemSkip in IF statement logic.
conflax
- Version: Various
- Excel Version: Various
Thanks guys, got around it with a new process variable
Steve
Steve
