Parallel execution of TI Processes
EP_explorer
OLAP Product: PAL
Version: 2.0.9
Post by EP_explorer »
I'm faced with the next situation
TM1 server which installed on server with several processor cores. TM1 Application (Contributor application). In application users launch TI processes by click on buttons. And as I see when first user launch TI process it is executed on 1 processor core. When second user launch TI process, it is waiting the end of first process and only after it starts and executing on the same processor core. And other cores are free in this times.
Is it possible to tune TM1 that it starts using other cores in this situation?
Re: Parallel execution of TI Processes
EP_explorer
OLAP Product: PAL
Version: 2.0.9
in .cfg file put ParallelInteraction=T
by default - so apparently the thing is in something else.
Post by David Usherwood »
Think you need to read the whole of the IBM best practice note, especially as regards locking, and look at what's going on in your server log.
jameswebber
Version: CE 10.1.1
Post by jameswebber »
There is a good section on this in the new IBM tm1 book,
But check out this it might help (thanks to Ben Hill http://blog.tm1tutorials.com/?p=431)
Also what version of Tm1 9.5 are you on?
