I'm trying to install IBM Cognos TM1 v9.5.1 on a Windows 2008 R2 64-bit (IIS 7, .net framework 351 SP1). When I run the installation wizard while selecting the components, I am able to see only
TM1 Server
TM1 Perspectives
I am unable to see TM1 Web & TM1 contributor in the installation wizard, could you please tell what else should I enable on my machine to enable these options.
Thank You,
Radhika
TM1 installation error on Windows 2008 R2
- rkaif
- Version: 9.1 or later
Re: TM1 installation error on Windows 2008 R2
Are you running the setup as an Administrator? (Right click on setup file and run-as admin)
Cheers!
Rizwan Kaif
Rizwan Kaif
moby91
- Version: 9.5.1
- Excel Version: 2003 2007
There are two versions of the TM1 software for Windows:Radhika wrote:I am unable to see TM1 Web & TM1 contributor in the installation wizard
The 32-bit version for Windows x86 and the 64-bit version for Windows x64.
When you install the 32-bit TM1 software for Windows x86 on 64-bit Windows x64 the only install options are TM1 Server and TM1 Perspectives.
Are you trying to install the 32-bit TM1 software for Windows x86 on 64-bit Windows x64 ?
