I tried using the following found in another thread:
v 1.0 23 August 2010
' Written by Martin Ryan based on code from Mike Cowie in the TM1 Forum
' http://forums.olapforums.com/viewtopic.php?f=3&p=4468#p4468
Declare Function TM1_API2HAN Lib "tm1.xll" () As Long
code]' #### SAMPLE CALL ####
Sub sampleTICall()
Dim tm1ServerName As String, procName As String
Dim p1, p2, p3, p4, p5, p6, p7 As String
'--- Update this section as required
tm1ServerName = "tm1_library" ' the name of the TM1 server
procName = "DataExport_AnyDimension" ' the name of the process being called
p1 = "ID" ' The first parameter
p2 = "No" ' The second parameter
'--- end updates section
MsgBox RunTIProcess(tm1ServerName, procName, p1, p2)
End Sub
' #### END SAMPLE CALL ####
'HELPER FUNCTION TO GET TM1 API SESSION HANDLE
' This allows you to leverage TM1 Excel Client's active connection to your TM1 Server
Public Function GetExcelSessionHandle() As Long
GetExcelSessionHandle = Application.Run("TM1_API2HAN")
End Function
'EXECUTE PROCESS FUNCTION
Public Function RunTIProcess(ByVal ServerName As String, ByVal ProcessName As String, ParamArray ProcessParameters()) As String
Dim SessionHandle As Long, ValPoolHandle As Long
Dim ServerHandle As Long, ProcessHandle As Long
Dim TotParams As Long, i As Long, RawParameterArray() As Variant, ArrOffset As Byte
Dim InitParamArray() As Long, ParamArrayHandle As Long
Dim ExecuteResult As Long, numResults As Integer, k As Integer, myMsg As String
Dim iType As Integer, errStr As String * 75, tempVal As Long, returnStr As String * 75
'Get handles
SessionHandle = GetExcelSessionHandle()
If SessionHandle = 0 Then
RunTIProcess = "ERROR: Cannot communicate with TM1 API."
Exit Function
End If
ValPoolHandle = TM1ValPoolCreate(SessionHandle)
On Error GoTo Cleanup_API
'Get handle to server; check if connected
ServerHandle = TM1SystemServerHandle(SessionHandle, ServerName)
If ServerHandle = 0 Then
RunTIProcess = "ERROR: Not connected to server " & ServerName & "."
GoTo Cleanup_API
End If
'Get handle to process; check if valid
ProcessHandle = TM1ObjectListHandleByNameGet(ValPoolHandle, ServerHandle, TM1ServerProcesses, TM1ValString(ValPoolHandle, ProcessName, 0))
If TM1ValType(SessionHandle, ProcessHandle) <> TM1ValTypeObject Then
RunTIProcess = "ERROR: Unable to access process " & ProcessName & "."
GoTo Cleanup_API
End If
If TM1ValObjectCanRead(SessionHandle, ProcessHandle) = 0 Then
RunTIProcess = "ERROR: No permissions to execute process " & ProcessName & "."
GoTo Cleanup_API
End If
' Get parameters, build array of param & type
TotParams = UBound(ProcessParameters)
If TotParams < 0 Then 'No parameters passed
ReDim InitParamArray(1)
InitParamArray(1) = TM1ValString(ValPoolHandle, "", 1)
ParamArrayHandle = TM1ValArray(ValPoolHandle, InitParamArray, 0)
Else
ReDim RawParameterArray(TotParams, 1)
'Collect the params, get their type
For i = 0 To TotParams
RawParameterArray(i, 0) = ProcessParameters(i)
If VarType(ProcessParameters(i)) = vbString Then
RawParameterArray(i, 1) = "S"
Else
RawParameterArray(i, 1) = "N"
End If
Next i
'Now array of handles to params for process
ReDim InitParamArray(TotParams)
If RawParameterArray(i, 1) = "S" Then
InitParamArray(i) = TM1ValString(ValPoolHandle, CStr(RawParameterArray(i, 0)), 0)
Else
InitParamArray(i) = TM1ValReal(ValPoolHandle, CDbl(RawParameterArray(i, 0)))
End If
Next i
'Set the parameters in TM1 array
ParamArrayHandle = TM1ValArray(ValPoolHandle, InitParamArray, TotParams + 1)
TM1ValArraySet ParamArrayHandle, InitParamArray(i), i + 1
Next i
End If
'Execute process
ExecuteResult = TM1ProcessExecuteEx(ValPoolHandle, ProcessHandle, ParamArrayHandle)
'ExecuteResult is an array containing information about the error type (minor, ProcessQuit, etc) and a reference to the error log location
iType = TM1ValType(SessionHandle, ExecuteResult)
If iType = CInt(TM1ValTypeIndex) Then
RunTIProcess = "Process executed successfully"
ElseIf iType = CInt(TM1ValTypeArray) Then
'Retrieve the error
TM1ValErrorString_VB SessionHandle, TM1ValArrayGet(SessionHandle, ExecuteResult, CDbl(1)), errStr, 75
'Retrieve the error log file
TM1ValStringGet_VB SessionHandle, TM1ValArrayGet(SessionHandle, ExecuteResult, CDbl(2)), returnStr, 75
showProcessError errStr, returnStr
RunTIProcess = "Errors occurred during process execution"
ElseIf iType = CInt(TM1ValTypeError) Then
RunTIProcess = "Returned an error value. The process was not run for some reason"
ElseIf iType = CInt(TM1ValTypeBool) Then
RunTIProcess = "Returned a boolean value. This should not happen."
ElseIf iType = CInt(TM1ValTypeObject) Then
RunTIProcess = "Returned an object. This should not happen."
ElseIf iType = CInt(TM1ValTypeReal) Then
RunTIProcess = "Returned a real number. This should not happen."
ElseIf iType = CInt(TM1ValTypeString) Then
RunTIProcess = "Returned a string. This should not happen."
Else
RunTIProcess = "Unknown return value: " & iType
End If
Cleanup_API:
TM1ValPoolDestroy ValPoolHandle
End Function
Sub showProcessError(reason As String, fileName As String)
Dim myMsg As String, filePath As String, logPath As String, fso
On Error GoTo errorHandler
Set fso = CreateObject("Scripting.FileSystemObject")
' Retrieve the log path that the user set in the options dialog box.
logPath = GetSetting(gSC_APP_NAME, gSC_REG_SECT_OPTS, gSC_REGKEY_LOGDIR, "") & "\"
filePath = logPath & fileName
' Check they've specified a log path
If logPath = "\" Then
myMsg = "There was an error when running your process. Specify a logging directory " & _
"in the TM1 Tools options dialog box to be able to view the error log from this workbook. The error message was " & reason
MsgBox myMsg, vbOKOnly, "An error occurred"
' Check they've specified a valid log path
ElseIf Not fso.FolderExists(logPath) Then
myMsg = "There was an error when running your process, but I can't find the error directory. Check you have specified it " & _
"correctly in the TM1 Tools options dialog box and that you have access privileges. The error message was " & reason
' If we can find the error file then give them the option of opening it
ElseIf fso.FileExists(filePath) Then
myMsg = "There was an error when running your process. Do you wish to view the error log? The error message was " & reason
If MsgBox(myMsg, vbYesNo, "View error log?") = vbYes Then
If Dir(filePath) = "" Then
MsgBox "I was unable to open the file. The path is " & filePath
Else
Workbooks.Open filePath
End If
End If
Else
' Incorrect parameters (either how many of them, or incorrect numeric/string type) sticks a '$' on the end of the error
' log and is locked by TM1 so we can't open it. There may be other reasons too.
myMsg = "An error occurred but I cannot find the error log. This may something is wrong with " & _
"the parameters, or that the error log folder you have specified is incorrect. " & _
Chr(13) & Chr(13) & "The error message was: " & reason
End If
Exit Sub 'avoid error handler
errorHandler:
MsgBox "An unknown error occured in the showProcessError sub of the bas_TurboIntegrator module in the TM1_Tools addin"
End Sub ellissj3
Version: 9.4.1 FP3 and 9.5.1
Private messageE-mail ellissj3AIM
once i had declared all functions it still did not work. Can anyone please point out what im doing wrong?
i am simply trying to run a TI from a userform with 1 or 2 parameters passed That is all!!! why is this so difficult? can i create an action button on a userfrom if so how?
i would prefer the VB in truth but if theres a more efficient work around im all ears!!
thanks guys for reading
