Server crash after Export to Textdata
holger_b
Post by holger_b »
Dear forum,
before I take the effort to set up a PMR, has anyone ever encountered anything similar? We twice experienced a server crash executing the following steps:
Create a view in a TI process (process is ended by ProcessQuit immediately after this)
Export the view to a text file using Export to Textdata
The export file contains just one line, I would expect a few more. These are the last lines in the log:
10844 [453] ERROR 2012-06-04 15:51:32.415 TM1.Process Process "6014_Subversion_to_Data_copy_All_Sources_physical_copy": : Execution was aborted by ProcessQuit Function.
10844 [453] ERROR 2012-06-04 15:53:23.348 TM1.Cube db_NXTREC::initializeReferences: Failure to reference the target cube with index: '0'. Ending iteration.
This is 9.5.2, Fixpack 2.
Any hints?
Thank you
Holger
Duncan P
Version: 9.5.2 10.1 10.2
Excel Version: 2003 2007
Re: Server crash after Export to Textdata
Post by Duncan P »
You did a ProcessQuit.
holger_b wrote: 10844 [453] ERROR 2012-06-04 15:51:32.415 TM1.Process Process "6014_Subversion_to_Data_copy_All_Sources_physical_copy": : Execution was aborted by ProcessQuit Function.
Everything you did in the process should get rolled back at this point.
Why not do a ProcessBreak?
holger_b
Post by holger_b »
Duncan, I can hardly believe that, since I do that regularly to check the outcome of processes, like the views I create. I do not use ProcessBreak since that executes the epilog tab, which I do not want.
Delbrooks
Version: 9.0
Post by Delbrooks »
Check the source view. All the dimensions in the view need to be in rows column. When the source is corrupted generally then you get such an error.
~D
AmbPin
Version: 9.5.2
Excel Version: 2007-10
Post by AmbPin »
I too have seen this error and have raised it through our support vendor. IBM have been able to recreate the problem too. We only started getting this when we installed FP2.
holger_b
Post by holger_b »
Thank you AmpBin! Can you indicate the SR number please?
Holger
AmbPin
Version: 9.5.2
Post by AmbPin »
I am afraid it disapears into a black hole so I don't get to see any numbers.
kangkc
Version: 2.x
Excel Version: 36x
Post by kangkc »
Just got hit and whole server just went down. 9.5.2 FP2.
Exact same message in log and was doing a export text file from view.
I found the APAR opened in IBM PM68926 on the 16 Jul 2012.
My worry now is this is such a common use feature and I'll seeing TM1 crashing every other day. Goodness. :shock:
Gabor
Post by Gabor »
I had the same issue running with 9.5.2 FP2 (HF1 ...HF3 applied). It even appeared while simply using the Textoutput to .cma in Server Explorer.
Have applied the newer Hotfixes now (HF4...HF6 / on the server only) and it seems to work fine.
Gabor wrote:I had the same issue running with 9.5.2 FP2 (HF1 ...HF3 applied). It even appeared while simply using the Textoutput to .cma in Server Explorer.
I also had a PMR raised for this but kind of let it slide as a "reproducible test case" would have involved purposefully crashing a server to get a dump file. No thank you IBM. Good to know that the latest HF for FP2 seems to have this fixed, someone else must have had more perseverance with IBM support than I did, they certainly believe in the concept of "innocent until proven guilty" when it comes to recognizing bugs.
Helmar
Version: 9.1 SP4
Post by Helmar »
I also encountered this annoying issue several times! In my experience, server preferably crashes, when a number of consolidated elements being referred to in several dimensions of the view to be extracted.
ibm states, that it still occurs even with HF6, see -->
http://www-01.ibm.com/support/docview.w ... wg1PM46816
"... TM1 server crashes when there are a number of write users working on a cube and a writer exports cube data with the Export as Text Data function."
ibm's recommendation is a 10.1 upgrade !!!
holger_b
Post by holger_b »
... just an update re this:
It turned out that the problem occurs especially when the LockPagesInMemory parameter is present in the tm1s.cfg, no matter if it is set to true or false. Apparently this leads to problems especially if there is another database on the same server which uses that parameter as well.
