Ghost of text attributes past
yyi
Post by yyi »
The Scenario;
  • 01. 2 new text attributes added to a dimension
    02. an unrelated requirement to replace files in data directory from previous day backup
    03. [server restarted with backed up data dir]
    04. ...
    05. the 2 attributes are subsequently added back
    06. attrs() in t.i. and =dbra() in worksheet can't read from those 2 attributes
    07. ?!?
    08. the 2 attributes are deleted
    09. the same 2 attributes are added again
    10. attrs() and =dbra() on the exact same attributes now start to work
    11. [no }ElementAttributes_ unloaded or server bounce involved after the restart]
only theory i have is that it was conflicting with the attribute names which were replaced by
the file replace in data directory, then where would it store that info :?:
Yeon
Version: PA 2.0.7
Re: Ghost of text attributes past
Post by jim wood »
I have had this one before. It retains the text attribute setting in cached memory. The only way I have found to solve this issue is to restart the service. If you do a search you'll probably find a post already covering this issue,
Jim.
