Hide dimension elements with mdx subset
Posted: Thu Jun 07, 2012 2:01 pm
I'm using 9.5.2 and excel 2007.
The end user of the model that I have built wants the ability to deactivate elements of a "Prospects" dimension so that they do not appear in any input sheets/reports etc. I have created a TI to put "IN-ACTIVE" in the "Status" attribute of the dimension.
I have then created a dynamic subset called "Prospects_Expand_All_Active" using the following code:
It strips out those elements that do not have "ACTIVE" in the status attribute. This works fine.
The input sheet is an active form. The TM1RPTROW formula in this active form references the "Prospects_Expand_All_Active" subset described above, so only shows "Active" elements - all good.
The Issue:
The subset works fine (it only displays active elements) until you roll up/drill down. Once you do this it will display all elements under a consolidation regardless of the STATUS. For example, the active form (input sheet) displays all active elements in the subset. However, if the user rolls up a consolidation and then drills down again both the active and inactive elements will be seen beneath the consolidation.
So I assume that just like when in subset editor, once you modify the subset (like rolling up/drilling down) it stops being a subset created by an expression and starts being a static subset. What I need is a subset where the elements with "inactive" status remain hidden.
Any ideas would be much appreciated.
Many thanks
{FILTER( {TM1DRILLDOWNMEMBER( {TM1FILTERBYLEVEL( {TM1SUBSETALL( [Hierarchy] )}, 5)}, ALL, RECURSIVE )}, [Prospects].[Status] = "ACTIVE")}The input sheet is an active form. The TM1RPTROW formula in this active form references the "Prospects_Expand_All_Active" subset described above, so only shows "Active" elements - all good.
The Issue:
Many thanks
