Tm1 Server Crash
andre lie
Tm1 Server Crash
Post by andre lie »
I run a series of dimension update TI processes via a main TI process using ExecuteProcess functions (9.5.2 FP2, Windows Server 2008, ODBC connection to SQL Server). Sometimes, the TM1 server crashes during execution of one of the TI processes. However if I run the individual TI process when the crash happens, the process could complete successfully. I could also run the whole series of TI processes without any problem some other time.
Whenever the server crashes, I get this message:
E20) Unable to save cube }DimensionProperties. Server 'abc' is going to be terminated and no data will be saved
I wonder if this is because of locking contention on the }DimensionProperties, but not sure how to avoid it if possible as that cube is a control object.
Andre
Version: PA 2.0.7
Re: Tm1 Server Crash
Post by jim wood »
Did you set the flag so the process execute waits for the previous to complete?
Shop at Amazon
Duncan P
Version: 9.5.2 10.1 10.2
Excel Version: 2003 2007
Post by Duncan P »
I thought that that flag was only on the ExecuteCommand call. Unless of course OP is using TM1runTI.EXE asynchronously in which all bets are off.
Martin Ryan
Post by Martin Ryan »
Perhaps try the zLock cube idea in this post. Your processes should be executing in sequential order any way, but it's possible they're overlapping and this will prevent that.
andre lie
Post by andre lie »
Thanks for all the replies
The TI processes are indeed supposed to run in sequential order as the main TI process looks like this:
ExecuteProcess('Process 1');
ExecuteProcess('Process 2');
# In the Epilog of Process 2
ExecuteProcess('Process 2a');
ExecuteProcess('Process 2b');
ExecuteProcess('Process 3');
ExecuteProcess('Process n');
The main TI process is execute by a chore. Users do not have access to run the main TI process and its individual processes.
Andre
