TM1 Contributor Could Not Login and Could Not Create App
Posted: Tue May 29, 2012 2:47 am
Hi all, if you can give me some help
I have TM1 9.5.2 FP2 installed on my windows vista machine. Prior to upgrading to 9.5.2 and 9.5.2 FP2, I had a working 9.5.1 contributor application running on top of tm1 instance 'A'
Now, I want to run 2 TM1 instances ('A' and 'B'), use the existing contributor application on instance A and make new apps on instance B. However, I do not manage to create any application using instance 'B'. There are 2 conditions that produce errors
1. Instance A and B are running (I could login to both instances using Perspectives, using the same user ID). I manage to login to contributor successfully, and could see and open existing application on instance A. Then I start the Design Application to create a new app on instance B.
When create new planning application dialog appears and i input the app name, select the tm1 server name (instance B) and click ok, I always get error message: The application will now exit as the connection with TM1 server was interrupted, and then TM1 contributor administration tool is automatically closed
2. If only one instance is running (instance B), I am never able to login to contributor page. I always get message: Could not logon to any available servers with the provided credentials
In summary, it seems that i have to start tm1 instance A to be able to login to contributor, even though it is successful, i still could not create application on instance B
Andre
Andre
