the navigation pane of our TM1 Web application looks like this:
--> Applications
App1
App2
App3
--> Views
ReportingCube1
TechnicalCube1
ReportingCube2
TechnicalCube2
The users have access to the applications and can edit and save the reports under applications with a new name.
The saved new report is then located in the navigations pane under views. Therefore the users have to switch to views to see their new applied report.
The users can now see under views the technical and reporting cubes of our application, but this is unwanted. The user is only allowed to see the reporting cubes.
There are two possible solutions for this issue. But I couldn't figure out how to implement this solutions. Maybe some of you could help!
1.) Is it possible to hide some selected cubes in the views? (hide the technical cubes)
There is already one topic concerning this, but the use of security is not the appropriate approach.
http://www.tm1forum.com/viewtopic.php?f=3&t=4654
2.) Is it possible to automatically publish reports from views to applications?
If the reports are automatically published from views to application, we could hide the hole view node.
I hope I have explained our problem in an understandable way
Thank you very much for your help!
Kind regars,
Daniela
