I have just built integrated login at a client. Since (in my experience) ETLDAP doesn't work (mainly dreadful documentation), the update of users is via a script generating a file which is processed via TI. All works well.
But I need to move the stuff back to Dev, which won't be using integrated login. I would like the TI to test the server name and bailout if it isn't Prod. Any ideas? All I can think of is to read the TM1S.CFG file (which we always keep in the server directory, but doesn't have to be there).
Determining server name in TI
- Steve Vincent
- Version: 10.2.2 FP1
Re: Determining server name in TI
Dave, its already discussed in this thread. Granted if you search on "server" and "name" it tells you there are too many terms, but "servername" came up trumps
Thanks. I have taken the approach of reading the CFG file into a string cube, which works well. Of course when _writing_ the TI I had to specify a server specific path on the first file box, but I think the result should be portable.
