How to Disable Taking Ownership in a Central Application
Posted: Sun May 20, 2012 7:05 pm
by mce
In TM1 10.1, in central application, is it possible to disable users taking ownership?
I want all users using the application concurrently without reserving it.
When a user takes ownership, it becomes read only for others and someone needs to take ownership and then release for everyone to be able to continue entering.
In order avoid this happening, I want to disable users being able to take ownership in the central application, and still allow them enter data without taking ownership.
Thanks for any responses.
Re: How to Disable Taking Ownership in a Central Application
Posted: Sun May 20, 2012 7:55 pm
by declanr
If you are having multiple users work on the data rather than following the rigid one person input, submit, approve routine could it not be more suitable to avoid contributor (Application) and just build some websheets (with action buttons to submit and approve if necessary)?
Posted: Sun May 20, 2012 8:21 pm
by mce
declanr wrote:If you are having multiple users work on the data rather than following the rigid one person input, submit, approve routine could it not be more suitable to avoid contributor (Application) and just build some websheets (with action buttons to submit and approve if necessary)?
Yes, we could use websheets, but we will make use of Cognos Insight, rather than websheets. It has the capabilities for action buttons and navigation to different pages. We think it will have many superior advantages wrt websheets. In TM1 Applications Web (new Contributor), we can still use websheets anyway, in a central application.
Posted: Thu Jul 19, 2012 5:12 pm
by image2x
*bump*
Same question. Anyone found a way?
Thanks.
-- John
Posted: Thu Jul 19, 2012 11:59 pm
by nick_leeson
In TM1 10 there are new types of applications i.e. Contributor Applications that you could make use of. I think in your case you could use the Application Type Responsibility.
More Info here http://publib.boulder.ibm.com/infocente ... /index.jsp
By using this users will be able to write concurrently without data being reserved or users taking ownership.
I don't think the combination of TM1 Applications Web (new Contributor) and Websheets will resolve this problem as the moment a user takes ownership of the node , data will reserved and this will cascade into Websheets.This "feature" does not work the same way in Cognos Insight i.e. users will be able to write to data to the intersections that have been reserved.
Its nice little "feature" but could potentially be a bug because it goes against the principles of Data Reservation so that could come back to bite you in subsequent releases.
"Data Reservation (DR) is a server-related feature in TM1 that allows you to configure exclusive write-access to regions of a cube for individual users. Once reserved, the data in that region can only be modified by that specific user until the reservation is released". This is from TM1 10 Documentation .
