Excel DisplayAlerts
Posted: Fri May 18, 2012 11:46 am
by kwakkers
Hello everyone
We have some vb code that saves all the tm1 sheets in a file into csv files. Upto now the user had been manually clicking on OK to save the sheets. I thought I could change this by turning off displayalerts as part of the process.
This works just fine when I am not connected to TM1, but it seems to ignore it when connected (and the user had to click ok for every save). Could anyone offer a potential cause and solution? Any help would be appreciated.
The code I have is:
Sub SaveMultiSheetWorkbookAsCSVFiles()
 Dim path As String
 Dim workbookfilename As String
 Dim count As Integer
 Dim myday, mymonth, myyear As Integer
 Dim workbookname, sheetname, fname As String
 Dim dlgFolderPicker As FileDialog
    Set dlgFolderPicker = Application.FileDialog(msoFileDialogFolderPicker)
    If (dlgFolderPicker.Show() = -1) Then
        path = dlgFolderPicker.SelectedItems(1) & "\"
        workbookfilename = ActiveWorkbook.Name      ' get the current workbook name so we can switch to it as we save individual worksheets
        i = InStrRev(workbookfilename, ".")
        If (i > 1) Then
            workbookname = Left(workbookfilename, i - 1)
        Else
            workbookname = workbookfilename
        End If
        Windows(workbookfilename).Activate
        count = ActiveWorkbook.Worksheets.count
        myday = Day(Date)
        mymonth = Month(Date)
        myyear = Year(Date)
        [b]Application.DisplayAlerts = False[/b]  ' LL Added 2012-05-14
        For i = 1 To count
            ActiveWorkbook.Worksheets(i).Select
            sheetname = ActiveWorkbook.Worksheets(i).Name
            Sheets(sheetname).Copy      ' make a copy of the current worksheet so we can save it.
            fname = path & workbookname & "-" & sheetname & "_" & myyear & "-" & mymonth & "-" & myday & ".csv"
            ActiveWorkbook.SaveAs Filename:=fname, FileFormat:=xlCSV, Password:="", WriteResPassword:="", ReadOnlyRecommended:=False, CreateBackup:=False
            ActiveWorkbook.Close False
                        Windows(workbookfilename).Activate  ' switch back to the main workbook
        Next i
        [b]Application.DisplayAlerts = True[/b]    ' LL Added 2012-05-14
    End If
End Sub
Public Sub SetTempDirectory()
    frmSetDirectory.Show
End Sub
Re: Excel DisplayAlerts
Posted: Sat May 19, 2012 3:55 pm
by Wim Gielis
Hello kwakkers
I bet this will be a lot better code and more readable code:
    Dim path As String, fname As String, wb As Workbook, dlgFolderPicker As FileDialog
    If dlgFolderPicker.Show() = -1 Then
        Set wb = ActiveWorkbook
        Application.ScreenUpdating = False
        For i = 1 To wb.Worksheets.count
            With wb.Worksheets(i)
                fname = path & Split(workbookfilename & ".", ".")(0) & "-" & .Name & "_" & Format(Date, "yyyy-mm-dd") & ".csv"
                With ActiveWorkbook
                    .Saved = True
                    .Close 0
                End With
            End With
        Next
        Application.ScreenUpdating = True
    End If
End Sub
Posted: Mon May 21, 2012 9:24 am
by kwakkers
Hi Wim
You solution worked an absolute treat, and is definitely more readable. There was a slight issue with the code in regards to the filename as workbookfilename returned an empty string
I used to return what the users wanted.
fname = path & Split(wb.name & ".", ".")(0) & "-" & .Name & "_" & Format(Date, "yyyy-mm-dd") & ".csv"
Thank you so much for your help, it is greatly appreciated. ;)
Posted: Mon May 21, 2012 4:25 pm
by Wim Gielis
You're welcome, glad it helps.
