I have configured TM1 security with Cognos BI, and i am able to login TM1 architect with with BI login credentials. But i am unable to view the admin rights in TM1 architect, all options are disabled. Please let me know if any thoughts on this issue.
S/W versions: Cognos BI 10.1.1 and TM1 10.1
Kris
Disable Admin rights in TM1 Architect
winsonlee
- Version: 9.5
Re: Disable Admin rights in TM1 Architect
http://www.tm1forum.com/viewtopic.php?f=3&t=7344
will your issue be because of missing Tm1p8.Lic file ? Have a look at the link above see if it is the same issue you are having.
- Mike Cowie
- Version: Anything thru 11.x
Prior to changing your TM1 Server config to integrate with Cognos BI security (IntegratedSecurityMode=4 or IntegratedSecurityMode=5), did you go in and add your Cognos BI login credentials as an Admin group member in TM1 security?Krish wrote:I have configured TM1 security with Cognos BI, and i am able to login TM1 architect with with BI login credentials. But i am unable to view the admin rights in TM1 architect, all options are disabled. Please let me know if any thoughts on this issue.
I'm going from memory a bit here, but you first need to edit the TM1P.INI file and look for and add or update these settings:
AllowImportCAMClients=T
CognosGatewayURI=<your Cognos BI server gateway URL>Regards,
Mike
Mike Cowie
QueBIT Consulting, LLC
