I created a new TI-Prozess by opening an old prozess that does the same (but with an other datasource) and save with a new name.
when i run this new prozess (after the adjustments) there is following error: "This process is incomplete and can not be executed" (I'm using german so ...original text: "Dieser Prozess ist unvollständig und kann nicht ausgeführt werden").
Then i made a completely new prozess with datasource, parameters, prolog etc ... with the same result - also after a server shut down.
does anyone know this problem?
thx
hi again,
the problem was: in parameters was the same var-name as in the var-view ...
Should there not be a message that the variable is twice? mhhhh ...
by
