Number of possible users on a read only cube.
Posted: Tue May 15, 2012 7:30 am
All,
I'm curious about how many simultaneous users are able to work off a read only cube without a drop off in performance?
I appreciate this is a how long is a piece of string type question….
A hypothetical example then.
Say the cube concerned is 8GB (in RAM) of raw data with some currency calcs and few other bits and pieces nothing massively draining.
At any given moment we expect 500 users to be querying the data at the same time.
The box has 12 cores.
In older versions of TM1 you would design your system so that your data was in multiple cubes or instances so that the load of the users and data were split up to allow cores and threads to be utilised efficiently.
In the current versions of TM1 9.5.2 + it seems that the argument for segmenting the data in this way is much weaker.
Anyone have a view on the number of simultaneous users a single cube can support before performance degrades?
What is the correct remedy to this? Cut the data into multiple cubes or separate instances on the same box or separate instances on a different box.
Is the TM1 architecture irrelevant and the real limit the hardware?
(EDIT : Correct the bit about a different box which previously said the same box)
