10.1 contributor error in TM1
Posted: Sun May 13, 2012 4:09 pm
by charan
I am finding an error when I deploy the application, please find the attachment with this error also one more error I am getting like
Distributed planning client find the attachment as well.
Re: 10.1 contributor error in TM1
Posted: Sun May 13, 2012 4:31 pm
by declanr
Have you tried adding the parameters it suggests into the config file?
Posted: Tue May 15, 2012 5:59 am
by charan
What are the parameters to be added?
In have tried with distributed parameter by seeing the planning sample cfg file but it did not help, any suggestions please.
Posted: Tue May 15, 2012 8:38 am
by Andy Key
As your screenshots quite clearly show, the parameters to add to your tm1s.cfg file are
DistributedPlanningOutputDir=<enter a valid path here>
AllowSeparateNAndCRules=T
Once you have saved these changes, restart your TM1 service.
Documentation on both parameters can be found in the manuals.
