9.0 to 9.5 and do not overwrite
marina
OLAP Product: tm1
Version: 9.5
Excel Version: 10
Post by marina »
I have a problem ..
I developed with 9.0 of TM1 cubes on a server that I bring on a TM1 version 9.5 on another server where but I have already developed
other cubes other than those present in version 9.0.
How can I do without overwriting the contents of version 9.5 and migrate data from 9.0 to 9.5?
Thanks to all! :ugeek:
Re: 9.0 to 9.5 and do not overwrite
First migrate the 9.0 cubes to 9.5.x unicode within a separate server. Then copy the updated cubes and dimensions into the current 9.5.x database.
This will not overwrite anything unless you have name conflicts. In which case you will either need to rename objects or export and import data.
marina
OLAP Product: tm1
Version: 9.5
Excel Version: 10
Post by marina »
hello,
I did these steps but nn I solved my problem:
*) I turn off the service
*) I copy the folder CXMD (server 1 and version 9.0) inside \TM1Data\CXMD (server 2 version 9.5) going to change the names to the same file
*) restart the service
Architect run but then shows me the server CXMD nn but I can take no action.
Thanks to everyone for the help .. :D
marina wrote:Architect run but then shows me the server CXMD nn but I can take no action.
Do you mean that you can't log in to the service? e.g. you click on "CXMD" and nothing happens?
Or have you logged in but don't see any objects e.g. cubes and dims?
marina
OLAP Product: tm1
Version: 9.5
Excel Version: 10
Post by marina »
Hello and thanks for the reply,
under the icon "servers" does not even show me the folder "CXMD"..
If you open the server log file, where has it got to in its attempt to start up?
marina wrote:hello,
If you just copied the entire contents in the data folder from one TM1 server to another, did you bother to take a look at the tm1s.cfg file and make sure all the settings are appropriate for the new location? More specifically, did you make sure the DatabaseDirectory and LoggingDirectory options were valid?
marina
OLAP Product: tm1
Version: 9.5
Excel Version: 10
Post by marina »
Thanks for everything .. I had not changed the configuration file tm1s.cfg.
Thanks again for everything :roll:
