Disable DELETE button in TM1 Web
Posted: Wed May 09, 2012 8:43 am
by LukaszM
Hi everyone,
Is there any way to prevent users from deleting content of TM1 Websheet? When I apply a cell-level security it prevents users from enetering data and data validation takes care of picklists. But I actually can't prevent users from deleting data with delete button, regardless cell security and cell's data validation and if it's Active Form or just regular cell. What's worse, deleted cells remain empty even after switching websheets and when this occurs in Active Forms, the data is actually deleted from cube, regardless user permissions and websheet or cell security! (even applied in format range).
Any ideas?
Ɓukasz M.
Re: Disable DELETE button in TM1 Web
Posted: Wed May 09, 2012 12:30 pm
by tomok
Cell level security, huh? Did you assign a security to every single cell? Cell level security doesn't work the same way as element security (where an empty assignment means NONE), no assignment in a cell level security cube means that cell is wide open.
