TM1 Web 9.1.4 Setup
Posted: Tue Feb 17, 2009 1:08 pm
We're in the process of getting the architecture for TM1 web approved internally and the server team are asking alot of questions that I don't know the answers to so I wondered if anyone here could help me?
I've read through the TM1 Operations Guide Manual and tried to extract as much info as possible but I think there are still some gaps (big holes!) in my knowledge. Our tm1 application server is running on a 64 server with 9.1.4 64 bit tm1.
1. Confirmation OS can be Windows Server 2003 IIS6 32 bit (NOT 64 bit) - I believe that this is fine
Confirmation Web Servers can be virtual Also that this is ok
2. Technical summary of connection string between web server and application server (inc. overview of web server configuration file specifying DNS alias of application server) From the documentation it looks like it uses HTTP and also that we can enter the admin host name into the web.config file to automatically direct clients to the correct admin host?
3. Technical summary of dynamic files necessary on web server created by Excel and overview of how a multiple web server farm running in an active/active configuration would be configured to replicate these files if necessary As I understand it c:\inetpub\wwwroot\TM1Web\ExcelSheet contains an xls and xml for each published workbook plus folders for css files. The server team are talking about using a shared web farm and were questioning whether this meant that those files would need to be replicated across the farm?
4. Technical summary of recommended security configuration for web clients inc SSL I believe that you can choose whether or not to use SSL but aside from that I'm not sure how you would configure it?
And finally they aren't happy about running Excel on a server, and definitely not on a shared farm, I've found a Technical Bulletin on the cognos site about how to run TM1 web without Excel but suspect that this may have all sorts of adverse affects to performance - does anyone have any experience of it?
I realise thats alot of questions but all advice would be very gratefully received!
Sarah
TM1 Developer
RBS Insurance
Sarah
TM1 Developer
RBS Insurance
