Month Lookup Cube ?
youngjedi
Version: 9.5 - 10.1
Excel Version: Microsoft Excel 2010
Month Lookup Cube ?
Post by youngjedi »
I have a user input form where I collect input dates by day (5/12/2011), and for reporting purposes, I would like to consolidate these dates and put them them into a monthly format that looks like May-2011.
I do not need to report by day, just by month. What would be the best way to do this???
Much appreciated
asutcliffe
Version: 9.4.1 - 10.1
Excel Version: 2003 and 2007
Re: Month Lookup Cube ?
Post by asutcliffe »
youngjedi wrote:I have a user input form where I collect input dates by day (5/12/2011), and for reporting purposes, I would like to consolidate these dates and put them them into a monthly format that looks like May-2011.
Much appreciated
Are you using one time dimension? Can't you build in consolidated elements like May-2011 with all the days of May 2011 as children? Then just do your reporting on the consolidated element?
JDLove
Post by JDLove »
I would possibly use a TI process, you may benefit from a Date Lookup cube depending on your dimensionality.
mattgoff
Version: 10.2.2.6
Excel Version: O365
Post by mattgoff »
It sounds like the date is a measure, not a dimension, in your cube. If so, you're going to have to build a 2nd cube with either rules or TI linking it to your data entry cube.
Matt
youngjedi
Version: 9.5 - 10.1
Post by youngjedi »
To be clear I started with a date dimension that collected the date of input from an Excel user sheet. For reporting purposes I want to roll this into months so I can analyze trends. I was thinking of creating some type of look up cube but I like the idea of adding the monthly/yearly rollups in my existing dimension...
asutcliffe
youngjedi wrote:To be clear I started with a date dimension that collected the date of input from an Excel user sheet. For reporting purposes I want to roll this into months so I can analyze trends. I was thinking of creating some type of look up cube but I like the idea of adding the monthly/yearly rollups in my existing dimension...
Perhaps it might help if you post details of the relevant existing dimensions and cubes?
