roblightbody wrote:Does the fix pack affect any of the objects in the model? For instance, if hte test server is on FP2 and the live one isn't, can I copy TIs, rule files, cubes etc across from one to the other without problem? Could I copy the whole data folder over?
You can always copy all model files and run them on a newer server version. Most of the time (the 9.5 unicode transition is the only exception I know of) you can also go the other direction (take files from a newer version and run them on an older version), but it's probably not a good idea.
roblightbody wrote:If I install FP2 on the server only, will that cause any problems? (Clients will be updated too, but there might be a short gap).
No problem. We still have lots of clients running 9.5 even though we upgraded to 9.5.1 more than a year ago. It's probably best to keep the version numbers relatively close. We did have an issue with clients on 9.1.2 and the server on 9.2 and had to do a quasi-emergency client upgrade, but I think this was due to the introduction of SSL.
roblightbody wrote:We have a lot of issues with Excel crashing out when using Perspectives. Has anyone else had this problem, and has FP1 & 2 helped?
Every time one of my users has had this problem, it's been fixed by running Microsoft Update and ensuring all of the Office patches are applied. I can't speak to this FP specifically.
Matt
