TM1 & Jmeter
mcguija
OLAP Product: Cognos
Version: 9.5.2
TM1 & Jmeter
Post by mcguija »
I'm running Jmeter (batch load testing) with TM1.
The script opens websheets, refreshes, makes minor changes.
When I run with 10 users sometimes 1 of the users will not open a websheet. I get the following error: "Fail to find target websheet"
Any ideas?
Thanks!
j.
Re: TM1 & Jmeter
The only thing I can think that TM1 won't open a websheet would be because it can't find the hyperlink you provided. Are you sure your batch testing program is creating the exact same hyperlink for all the 10 users AND you have security set identically for all 10?
mcguija
Version: 9.5.2
Re: TM1 & Jmeter
Post by mcguija »
I can see which user is failing. If I login to tm1web manauly using that same user the websheet opens without issue so it shouldn't be a security thing, I think.
Also I think if it was security the error message would be different, in that case it is finding the websheet just not able to continue, in my case it doesn't seem to be finding it. Unless the error it is throwing isn't accurate to the symptom.
Keep the ideas coming.
j.
nick_leeson
Version: TM1 10
Re: TM1 & Jmeter
Post by nick_leeson »
Sorry have you got this working ?
