Lost Admin password
Posted: Wed Apr 11, 2012 8:29 am
by swati_phadtare
I have lost our Admin password of the application.
Please let me know how to retreive the admin password.
If not possible then how to reset it.
Re: Lost Admin password
Posted: Wed Apr 11, 2012 8:43 am
by qml
Depending on whether you have any other account that has Admin or SecurityAdmin privileges, you can use that account to delete the password directly from the }ClientProperties cube (manually, via TI or via the security GUI).
If you were careless enough not to have a backup Admin account then your next option is to delete the }ClientProperties.cub file from the data directory and restart the server. Be aware that this will remove passwords and other user settings for all users, not just Admin!
Posted: Wed Apr 11, 2012 8:58 am
by declanr
Another option would be messy but feasible...
Find a user that has access to run a TI, any given TI will do.
In your dev environment (if you have one and access to it) create a TI that uses the AssignClientPassword function.
Copy and paste that into the production environment after naming it the same as the TI your standard user has access to (make a copy of what it is replacing of course.)
Run and replace your admin password... in the event that you don't have a Dev environment I expect the bedrock site may have a TI that does this?
But definitely always have at least 2 admin users - just for the sake of resetting each others passwords.
HTH
Edit - I should add that I have never actually tested this and I am just presuming it might work - would be good to know if it actually does...
