Subset Editor flash past!
guoshock
Version: 9.5.1
Excel Version: MS Office 2007
Post by guoshock »
In the Cube Viewer,i click on a title dimension,the Subset Editor should come out.But the window just flashed past,I'm so puzzled by it,is there anybody met this before?
Thanks in advance!
Olivier
Version: Tm1 10.2.2fp4 -> 2.09
Excel Version: Excel 2013 - 2019
Re: Subset Editor flash past!
Post by Olivier »
If you have used dual monitor before the subset editor might just be showing on the other screen.
This post can help you to resolve this :
http://www.tm1forum.com/viewtopic.php?p=9688
Hope this helps.
HTH
Olivier
guoshock
Version: 9.5.1
Post by guoshock »
Olivier wrote:If you have used dual monitor before the subset editor might just be showing on the other screen.
Hope this helps.
I'm really appreciate of you,thank you!
I'll look into it.
guoshock
Version: 9.5.1
Post by guoshock »
Thanks again!Olivier,I do solve the problem according to you post.
