ODBCOUTPUT Double Quotes in Code
Posted: Mon Apr 09, 2012 6:58 pm
by dfrench77
ODBCOUTPUT command is not updating the SQL Sever table. I suspect it is because of the double quotes wrapped around the insert command generated in the asciiout file.
Below is my complete code from the data tab:
## Push Data into the SNO table (StartingInventory)
vsModel = ''| Model|'' ;
ItemCode = ''| Items|'';
Location = ''| Locations|'' ;
TranType = ''| HoldType|'';
Quantity =  Value;
UserID = ''| V2|'';
CreateDate = ''| vsCreateTime|'';
asciioutput('temp.txt',Expand( 'INSERT INTO [SNO].[dbo].[StartingInventory] ( [Model], [ItemCode], [Location], [TranType], [Quantity], [UserID], [CreateDate] ) VALUES ( ''%vsModel%'', ''%ItemCode%'', ''%Location%'',''%TranType%'',''%Quantity%'',''%UserID%'', ''%CreateDate%'' )' ) );
ODBCOutput('ODS', Expand( 'INSERT INTO [SNO].[dbo].[StartingInventory] ( [Model], [ItemCode], [Location], [TranType], [Quantity], [UserID], [CreateDate] ) VALUES ( ''%vsModel%'', ''%ItemCode%'', ''%Location%'',''%TranType%'',''%Quantity%'',''%UserID%'', ''%CreateDate%'' )' ) );
Here is the temp.txt file output with double quotes.
"INSERT INTO [SNO].[dbo].[StartingInventory] ( [Model], [ItemCode], [Location], [TranType], [Quantity], [UserID], [CreateDate] ) VALUES ( 'Electro-Vinlys', '79', 'Plaquemine','silo',' 2000.000','Admin', '2012-04-09' )"
When I copy this code into SQL Server Management Studio and remove the double quotes from the statement it loads the data. Any help on how to remove the double quotes will be greatly appreciated.
Desi
Re: ODBCOUTPUT Double Quotes in Code
Posted: Mon Apr 09, 2012 7:44 pm
by Alan Kirk
dfrench77 wrote:ODBCOUTPUT command is not updating the SQL Sever table. I suspect it is because of the double quotes wrapped around the insert command generated in the asciiout file.
I can't recall whether this affects ODBCOutput as well, but the way to remove the double quotes from the ASCIIOutput is via the DatasourceASCIIQuoteCharacter variable. In the prolog you set it to an empty string ('').
Posted: Mon Apr 09, 2012 8:25 pm
by dfrench77
I guess my original post (question) was confusing. The code that I posted previously is generating the following error.
"Electro-Vinlys","Admin","silo","Plaquemine","79","1","Inventory Qty","2000.",Data Source line (1) Error: Data procedure line (44): Error executing SQL query: "INSERT INTO [SNO].[dbo].[StartingInventory] ( [Model], [ItemCode], [Location], [TranType], [Quantity], [UserID], [CreateDate] ) VALUES ( 'Electro-Vinlys', '79', 'Plaquemine','silo',' 2000.000','Admin', '2012-04-09' )"
When I take this statement without the double quotes and execute in MS SQL Server it updates the StartingInventory table, however I believe it is failing because TM1 Turbo Integrator code is placing the double quotes around the statement. Is this correct? Is my code putting the double quotes?
Posted: Mon Apr 09, 2012 11:26 pm
by Duncan P
The double quotes round the statement in the file are put there by ASCIIOutput and will not be present in the statement being executed by ODBCOutput. If you want to remove them from the file then set DatasourceASCIIQuoteCharater as Alan suggested.
You have a set of lines which give the appearance of putting quote characters round your data variables. However all they do is add an empty string to both ends. In other words they don't do anything and should be removed.
I presume your [Quantity] variable is numeric, in which case it should not have quotes round it.
...,''%Quantity%'',...
should be
...,%Quantity%,...
Having said that I cannot see how your statement is executing in SQL Server Management Studio unless you are also removing the single quote characters round the 79 you have for quantity.
Posted: Tue Apr 10, 2012 10:28 am
by rmackenzie
Duncan P wrote:I presume your [Quantity] variable is numeric, in which case it should not have quotes round it.
I think that's the problem as well.
Duncan P wrote:Having said that I cannot see how your statement is executing in SQL Server Management Studio unless you are also removing the single quote characters round the 79 you have for quantity.
Maybe SSMS does the necessary type conversion but the ODBC driver on the OP's TM1 server won't do this automatically?
Posted: Tue Apr 10, 2012 12:23 pm
by dfrench77
Thanks for you comments on the asciioutput. However, that is really not the issue. The issue is that the Insert command is not executing from the TI process. See error message below again. Please note the " " double quotes around the insert command.
"Electro-Vinlys","Admin","silo","Plaquemine","79","1","Inventory Qty","2000.",Data Source line (1) Error: Data procedure line (44): Error executing SQL query: "INSERT INTO [SNO].[dbo].[StartingInventory] ( [Model], [ItemCode], [Location], [TranType], [Quantity], [UserID], [CreateDate] ) VALUES ( 'Electro-Vinlys', '79', 'Plaquemine','silo',' 2000.000','Admin', '2012-04-10' )"
When I take this insert command without the double quotes and execute in MS SQL Server Management Studio the table is updated. Any insight on how to resolve this error would be greatly appreciated.
Desi
Posted: Tue Apr 10, 2012 12:39 pm
by Duncan P
The double-quote characters in the error log are put there by the error logging procedure to delimit the SQL statement that has the error. They are not part of the statement executed by ODBCOutput.
To confirm this assign the result of the Expand function into a variable and execute the CODE function to get the ASCII code of the first character, e.g.
sql_stmnt = EXPAND( .... );
initial_char_code = CODE( sql_stmnt, 1 );
If you are still not sure then open a profile in SQL Server Management Studio and log PrepareSQL. You will then see exactly what is getting through.
When you are convinced that double-quotes are not your problem try re-reading the previous posts.
Posted: Tue Apr 10, 2012 1:00 pm
by dfrench77
Duncan,
The attached file illustrates that the single quotes are not causing the issue. The attached file is the generic Insert command in MS SQL Server.
Here is the insert command generated from TI and executed in SQL Server
VALUES ( 'Electro-Vinlys', '79', 'Plaquemine','railcar','  -10.000','Admin', '2012-04-10' )
There is no issue executing this in MS SQL Server. I don't understand why TI is generating an error if the code works in SQL Server.
Desi
Posted: Tue Apr 10, 2012 1:12 pm
by Duncan P
Hi Desi,
I understand that in SQL Server Management Studio the statement is executing fine. However it would be interesting to know whether you have tried the modification to your code that I suggested. If you have and the error is still there then I suggest that you have two options available to you. You can trace within SQL Server http://msdn.microsoft.com/en-us/library/ms181091.aspx or you can trace the ODBC http://support.microsoft.com/kb/274551.
Let us know what results you get. Furthermore it would be interesting to see the structure of the target table and particularly the datatypes of the fields.
Duncan.
Posted: Tue Apr 10, 2012 1:26 pm
by dfrench77
Duncan,
I have tried to implement your suggested code, but have not been successful to this point. Here is the code I have so far:
sql_stmnt = Expand( 'INSERT INTO [SNO].[dbo].[StartingInventory] ( [Model], [ItemCode], [Location], [TranType], [Quantity], [UserID], [CreateDate] ) VALUES ( ''%vsModel%'', ''%ItemCode%'', ''%Location%'',''%TranType%'',''%Quantity%'',''%UserID%'', ''%CreateDate%'' )' ) ;
asciioutput('temp.txt', Expand( 'INSERT INTO [SNO].[dbo].[StartingInventory] ( [Model], [ItemCode], [Location], [TranType], [Quantity], [UserID], [CreateDate] ) VALUES ( ''%vsModel%'', ''%ItemCode%'', ''%Location%'',''%TranType%'',''%Quantity%'',''%UserID%'', ''%CreateDate%'' )' ) );
I have attached a file with the structure of the target table and particularly the datatypes of the fields.
SQL Server Insert Command.docx
(36.18 KiB) Downloaded 974 times
Desi
Posted: Tue Apr 10, 2012 2:30 pm
by Duncan P
Try this. Note that the %Quantity% does not have '' at each end.
ODBCOutput('ODS', Expand( 'INSERT INTO [SNO].[dbo].[StartingInventory] ( [Model], [ItemCode], [Location], [TranType], [Quantity], [UserID], [CreateDate] ) VALUES ( ''%vsModel%'', ''%ItemCode%'', ''%Location%'',''%TranType%'',%Quantity%,''%UserID%'', ''%CreateDate%'' )' ) );
Duncan.
Posted: Tue Apr 10, 2012 7:57 pm
by dfrench77
Duncan,
I tried your the code without the '' '' around %Quantity% and I still get the TI "Error executing SQL query".
Desi
Posted: Mon Apr 16, 2012 2:05 pm
by dfrench77
Duncan,
My apologies
The statement is working. Here is the code that I used.
I was receiving the error because I was trying to write a duplicate record to the table.
Thanks for your help.
Desi
Posted: Mon Apr 16, 2012 2:19 pm
by tomok
dfrench77 wrote:I was receiving the error because I was trying to write a duplicate record to the table.
Well, if that's the case then this statement can not possibly be true.
dfrench77 wrote:When I take this insert command without the double quotes and execute in MS SQL Server Management Studio the table is updated. Any insight on how to resolve this error would be greatly appreciated.
Posted: Mon Apr 16, 2012 2:24 pm
by Michel Zijlema
Well... the duplicate record could be caused by the running the test and then trying again to insert in TM1 :)
Michel
Posted: Mon Apr 16, 2012 3:26 pm
by dfrench77
This is correct. I was running the test without truncating or deleting the records from table. My apologies again. :)
Desi
