What should I do after I created a TM1 contributor App?
Posted: Sun Apr 01, 2012 6:50 am
by guoshock
Hi,all!I have just started to learn TM1 contributor,and I created a Demo contributor App,but then I don't know what to do next.Can anybody give some advices?
Thanks for reading.
Re: What should I do after I created a TM1 contributor App?
Posted: Sun Apr 01, 2012 9:34 am
by Wim Gielis
guoshock wrote:Hi,all!I have just started to learn TM1 contributor,and I created a Demo contributor App,but then I don't know what to do next.Can anybody give some advices?
Thanks for reading.
Hello
Did you set up a TM1 application? Created input/output views?
Set up an approval hierarchy and managed rights?
Is it all working the way you expect it to work?
Posted: Wed Apr 04, 2012 1:09 am
by Gregor Koch
How about you demo the Demo contributor App?
Posted: Thu Apr 05, 2012 9:47 am
by guoshock
Thanks for reading.
Hello
Thanks for reply.
Yes,I did set up an approval hierarchy and managed rights,and I also created views,but I didn't know what's input/output views means,could you please give me more detail ?For I'm really a new guy on TM1.
Posted: Thu Apr 05, 2012 10:01 am
by guoshock
Gregor Koch wrote:How about you demo the Demo contributor App?
Sorry to reply late.
I created the Demo App follow the "Contributor Administrator guide":dragged two views and put them under the VIEW,and dragged a Dimension subset under Approvals Hierarchy.After verified with no errors,I deployed,then I managed rights,but I don't what's to do next.Will you give me some advice or some materials about TM1?
Thanks anyway.
Posted: Thu Apr 05, 2012 10:05 am
by Edward Stuart
There are a few TM1 books available which include information on TM1 Contributer, otherwise speak to your managed provider about training or take one of the TM1 courses.
What do you need/ want it to do?
Posted: Thu Apr 05, 2012 6:29 pm
by rfielden
Did you validate and activate the application?
Posted: Fri Apr 06, 2012 2:10 am
by guoshock
Yes,I validated and activate the app.
In fact,I don't really know what can the contributor application do.
Posted: Fri Apr 06, 2012 2:22 am
by guoshock
Edward Stuart wrote:There are a few TM1 books available which include information on TM1 Contributer, otherwise speak to your managed provider about training or take one of the TM1 courses.
TM1 may be used on a project in our company,so I'm teaching myself about TM1 and no one can give me advice on it.
Could you give me some advice?
Thanks anyway.
Posted: Fri Apr 06, 2012 7:45 am
by Michel Zijlema
guoshock wrote:In fact,I don't really know what can the contributor application do.
From the user manual:
IBM® Cognos® TM1® Contributor streamlines data collection and workflow management. It eliminates problems with errors, version control, and timeliness that characterize decentralized planning processes.
So if your company is planning to use TM1/Contributor for planning/budgeting/forecasting or for consolidation with (lots of) manual data entry, the Contributor application is aimed at modelling the submission workflow of the 'contribution' process. If your company is looking to use TM1 for multidimensional analysis, loading data from f.i. a ledger and where no manual data entry is required, then you can forget about Contributor.
Michel
Posted: Fri Apr 06, 2012 8:50 am
by guoshock
Michel Zijlema wrote:So if your company is planning to use TM1/Contributor for planning/budgeting/forecasting or for consolidation with (lots of) manual data entry, the Contributor application is aimed at modelling the submission workflow of the 'contribution' process. If your company is looking to use TM1 for multidimensional analysis, loading data from f.i. a ledger and where no manual data entry is required, then you can forget about Contributor.
Michel
Thanks,Michel,I'm sort of understanding waht can TM1/Contributor do.
