Cannot access XXX.xru message after saving rules
- Version: Latest version
- Excel Version: 2003 to 2019
I have a TM1 model that was previously built by another developer. He did not use Rules Worksheet.
I have taken over this model and am now using Rules Worksheet to update the rules. Whenever I save the rules, a message appears after saving that says "Cannot access XXX.xru" where XXX is the cube.
Any idea how to get rid of this? Initially, I thought it was caused by an old BLB file. But there is no such file.
Thanks!
Harry
Thanks!
Harry
Re: Cannot access XXX.xru message after saving rules
Saving the XRU (using Rule Worksheet->Save, or the icon) will attempt to write to the relevant .xru file in the directory specified in the Data Directory option for the 'Local Server' per your TM1 options settings. This is a bit misleading/ confusing, because even though you may well be using a remote server, it will still take this path.
If you don't have write permissions on that folder then you may run into this issue although previously I have seen a simple 'Access denied' error. It is not uncommon for folders on the server to be subject to different read/ write permissions. You may have to speak to the administrator of that server in order for you to personally get a write permission, or you can set-up a totally separate share where all the XRU and XDI files are stored that a group of people can access.
Is that the issue?
Is that the issue?
Robin Mackenzie
Thanks for the reply, rmackenzie.
I don't think this is the issue as I'm currently developing using my local PC. I also faced the same problem when I'm logging in the server remotely and have write access to the folder where XRU and XDI files are stored.
Harry.
Harry.
Hmm, and is there an existing XRU to save over? Perhaps you need to create a brand new XRU and copy all the rules over into that?
Robin Mackenzie
- Version: 9.0 and up
- Excel Version: 2007 and up
I get this in 9.5.2 and it does not seem to be the access to the folder. The rule still will be compiled and the xru file will be saved, at least for me.
Just an annoying message that I click away and didn't bother to raise with IBM.
Which version of TM1 do you get the message with?
Using 9.5.2. Yes, it's just the irritating thing. Everything works fine.
I copied the original rules from Rules Editor and pasted into an Excel file, then changed the extension to XRU.
With 9.5.2 and XL 2010 combination I also get this saving an excel rule file every time. It's annoying but the XRU still gets saved just fine so I just don't worry about it.Gregor Koch wrote:Hi
Thanks for all your replies.
I'm using Excel 2010 on my local. However, in the server, I'm using Excel 2007. Both gave this error. Guess I'll just have to ignore it then.
harry
harry
- OLAP Product: TM1 9x, BPC, Hyperion, HANA
- Version: TM1 10
- Excel Version: Excel 2003 - 2010
The error exists in 10.1 on Excel 2007 as well.
- Version: 9.5.2 to 10.2
- Excel Version: 2007 - 2013
Harry,
This message has been around since at least 9.4 with Excel 2007
Even though I ignore it, if it wasn't there I would think there was something wrong
Just another one of those bugs that IBM Cognos will probably never address since it relates to Perspectives which they don't seem to put much priority into (actually no priority)
Being old school I prefer the XRU since I don't need a Rules Editor to write rules and I also prefer using spreadsheet functionality
It also gives me the ability to save older versions in a different tab similar to the XDI which I still use extensively as well
Certainly there are pros and cons to both methodologies but if you are an experienced Administrator/Developer the XRU may have some advantages
Bottom line as many of us know or perceive, IBM Cognos does not appreciate the spreadsheet so from my perspective I don't care about the annoying message since the functionality still works... at least for now!
Solanna
Solanna
