Display Only 1's from a Natural Consolidation
conray
Version: 9.5.2
Excel Version: Excel 2010
Post by conray »
I have 2 measure namely Std (Weight 1) and Act (Weight -1).
The natural consolidation measure is Diff:
Diff
|--Std
|--Act
I am trying to display all results of a set of materials if the natural consolidation evaluates to non-zero.
Currently, i am able to display the result using zero suppression when displaying the measure Diff.
But when i drill down, it will show every single materials including those which evaluates to zero.
Is it possible to achieve what i want to do?
Sorry if i didn't phrase my question properly caused i can't explain well in words :oops:
Server OS: Windows Server 2008 R2 (64-bit)
TM1: v9.5.2 FP1
MS Office: Microsoft Excel 2003, 2010
Re: Display Only 1's from a Natural Consolidation
It depends how you want to display the results but like the majority of things in TM1 there are a few options.
If it is possible for you to view it through an active form; my preferred method would be to create the active form based on a view which has zero supression turned on.
The column only showing the C-Level element and nothing else, the row being what ever else you do so fancy... this makes it so that only the consolidations that have a value are shown. I would then in the Excel sheet containing the active form add the 2 N-Level elements next to the existing column and stick the DBR formulas in.
Because the N-Level is not part of the view that the form is based on your zero-suppression should still work as desired.
Or you could create an extra consolidation that looks pretty much identical but the N-Level elements only pull through their original counterparts IF the orginal C-Level does not equal 0.
So say that your new elements are the same names but all prefixed with 'Z'
['ZStd']=N:
IF(['Natural Consolidation']=0,0,['Std']);
conray
Version: 9.5.2
Post by conray »
Hi declanr,
I will use your prefered method as its easier and faster to do, and also because method 2 requires me to perform additonal calculation on the cube.
Natural consolidation is still the best way to go :)
Thanks again for your suggestion.
TM1: v9.5.2 FP1
