TI process which last long time and TM1Web = error
Posted: Fri Mar 09, 2012 7:44 am
I created TI process which copies data from one Cube to another. Copying takes some time (approximately 5 minutes)
Then I made an Excel file with a button which run TI process and put the Excel file with the button in Tm1 application and opened it in TM1Web.
So when I clicked the button in TM1Web TI process launched and window of TM1Web started refreshing. It lasted near 2 minutes (110 seconds precisely) and after it window of TM1Web showed error (you can see error in attachment). TI process meanwhile ended without problems after 5 minutes. Problem is in TM1Web
Also I can add - if TI process lasts less than than the time I pointed (1,5 minutes for example) everything is ok. It seems I should change some settings in IIS or somewhere else but I don't know where.
Can anybody help?
Can anybody help?
