TM1 Web - Admin Dashboard
Eric
Version: 9.4
Post by Eric »
I am working on a TM1 Admin Dashboard. I saved it as a application file and it works fine, but when I trie to connect to it from the web I get an error. Anyone ever come across this issue?
If you want to load it on your system you should be able to use the Find/Replace on both tabs to update the server name. Other than that it should work.
Admin Dashboard.zip
Admin Dashboard
(42.25 KiB) Downloaded 743 times
Eric
mattgoff
Version: 10.2.2.6
Excel Version: O365
Re: TM1 Web - Admin Dashboard
Post by mattgoff »
I haven't done a thorough check or run this on my server. But, I did notice that you used RANK which is not supported in TM1 Web.
Matt
ScottW
OLAP Product: TM1 CX
Excel Version: 2003 2007
Post by ScottW »
Also be aware that as of 9.1 SP3 updating of "ACTIVE" status in the }ClientProperties cube has been disabled.
You can take tm1top logs and depending on what you do with them load to analysis cubes to let you know who was logged on an when, but obviously it's not going to be real time.
Scott W
Cubewise
www.cubewise.com
