TI Logic
mincharug.shulft
OLAP Product: Applix,Cognos TM!
Version: applix9.0Cognos tm1 9.5.1
Excel Version: Excel 2010 2007
TI Logic
Post by mincharug.shulft »
We have 100 dimensions like attached format, BUT we want it do delete it whichever elements were there under session consolidation element
And also we have under session consolidation element the following format C, S, N elements were there.
Please help here to get logic to delete c, s, n elements from the session consolidation elements..
Thanks in advance.
Doc1.docx
(16.72 KiB) Downloaded 306 times
Re: TI Logic
One word answer.
Bedrock.Dim.Unwind.TargetConsol.pro
Note: you would need to be careful to check whether any consolidation rolling up under "session" is also used in the region, area or control hierarchies, in which case you would get into no end of trouble if the sub-nodes were unwound as well.
mincharug.shulft
Re: TI Logic
Thanks for your reply.
no rolling up used in one another one.
could you please explain me little elabratly what condition could it be possible to put them away.
