c-level overriding rule and TI process
Posted: Tue Feb 21, 2012 12:31 pm
by gkatz
Hi all.
I'm tryin' to get data from a cube via TI-process.
I'm getting right data and everything fine except dimension elements which have c-level overriding rule like
['Rent.Distribution':'5'] = DB('Plan.Rent.input', !CurrencyVersions, !Locations.Rent, 'usd', !Date, 'Total', '3');
or
['Rent.Distribution':'3'] = ['Rent.Distribution':'2'] - ['Rent.Distribution':'1', 'BusinessUnits.Plan.Rent':'1'];
When i started to trace ti-process, i understood, that ti doesn't even try to process those elements.
I have picture describing all above:
http://dl.dropbox.com/u/7650174/ti.png
there 'cost of 1 sq. m.' doesn't processed by TI.
Could anyone please tell me how to get those values?
Re: c-level overriding rule and TI process
Posted: Tue Feb 21, 2012 12:59 pm
by Christopher Kernahan
Hi there,
I can't view the attachment but, in your TI process, have you set ViewExtractSkipRuleValuesSet=0 and ViewExtractSkipCalcsSet=0 ?
Posted: Tue Feb 21, 2012 2:22 pm
by gkatz
Yep, i've set this settings in prolog, but nothing has changed.
Posted: Tue Feb 21, 2012 3:55 pm
Can you confirm that those elements are in your Datasource? What have you got set for the ViewExtractSkipZeroesSet function?
Posted: Tue Feb 28, 2012 7:22 pm
by gkatz
Those three SET parameters were fine.
And i've found reason for described behavoiur: absence of feeders for such kind of rules.
TI process has started to work with feeders
