TM1 over Microsoft DirectAccess
naladar
OLAP Product: Perspectives
Version: 14.0.6112.5000
Excel Version: 14.0.6112.5000
Post by naladar »
Hello all,
Are any of you running TM1 over a Microsoft DirectAccess connection? The software works fine when I am on the LAN, I see packets going out the interface to port (tmadmsvr_ssl) 5498. But when I put it on the WAN, verify that the DA VPN tunnels are up and run a packet scan I don't see those packets. It is like the application is hardcoded to use its own connection method to the NIC which bypasses DA and breaks the application.
Any suggestions?
Re: TM1 over Microsoft DirectAccess
Hi Sorry to necro the post.
We have a client using M$ Direct Access from outside their domain and we are unable to get a Perspectives connection.
Perspectives works internally.
TM1 Web works remotely over Direct Access.
FYI Direct Access uses IPV6, does this have an impact?
EDIT
Found this
https://www.ibm.com/support/knowledgece ... eipv6.html
Will report back on if it resolves the issue
