Guys,
Do you know if Essbase is OLE DB compliant? Is it possible to connect TI to Essbase? I managed to find a paper stating the MSAS can connect to Essbase so that might be my work around if I'm not able to connect directly, the other option of course is export to good old flat file I guess,
Jim.
Importing Data From Essbase
- jim wood
- Version: PA 2.0.7
oliver sullivin
Re: Importing Data From Essbase
I don't believe TI can connect directly to essebase. I've always used the underlying data source via ODBC.
gstager
I don't believe Essbase is OLE DB compliant, unless that has been added in recent releases. Why not try the Essbase forums?
forums.oracle.com/forums/forum.jspa?forumID=405
network54.com/Forum/58296/
- jim wood
- Version: PA 2.0.7
Thanks for the replies guys. I've looked on the Essbase forums and all I can find is the MSAS work around,
Jim.
Jim.
