I want to set the hierarchy level to Day dimension. But the day dimension is not available in HierarchyProperties control cube.
I can able to see only the dimensions which are having hierarchial values.
Please give me some ideas.
Dimension in HierarchyProperties control cube
shyam bobburu
- Version: 9.5
- Excel Version: windows 2007
Andy Key
- Version: 2.5 to PA
- Excel Version: Lots
Re: Dimension in HierarchyProperties control cube
You either haven't got the Day dimension in your selection or your view is zero suppressed.
Andy Key
grantm15
- Version: 9.5.2
I have the same question. I have created a dimension that is currently being used in a cube. But I do not see that dimension in the {HierarchyProperties control cube to name the levels. I have tried EVERYTHING I can think of, and the dimension still is not visible in the control cube.
Thanks in advance...
Andy Key
I have the same answer
It definitely isn't appearing in the All subset of the }Dimensions dimension?
You defintely don't have either Row or Column or Both zero suppression?
Andy Key
