Hello All,
I am installing TM1 on Windows 2008 R2 and need clarifications on the various Port numbers that need to be opened and for my understanding how they communicate between TM1 Admin, TM1 Database and TM1 Web.
I have drafted a diagram for you to take a look. Page 1 of the pdf is simple basic architecture of SQL Server, TM1 Admin, TM1 Database and TM1 Web. I understand normally TM1 Admin and Database are on the same servers but in our case we have all Administrative tools within a common Server while Database resides on another server
Page 2 of Visio is where Port configurations are indicated (as per my understanding) and I get confused with the Inbound / Outbound, Source and Destination.
1. HTPPS Port for Web has been kept as 443
2. TM1 Admin shall listen to TM1 Web, would this be inbound default as 5495 (This is grayed out during installation and I don’t have a choice)
3. TM1 Admin shall listen to TM1 Web via SSL using 5498
4. TM1 Database shall listen to TM1 Admin using Port 12345
5. Also would TM1 Database listen to TM1 Web through Inbound Port 12345?
6. Turbo Integrator shall communicate with SQL Server thru Port 1433 using ODBC
7. I am not which Port shall have Excel Perspective communicate with TM1 Database
8. The TM1ExcelPortNumber parameter specifies the port number at which TM1 Excel Service is listening. Port Number 4785 (This needs to be edited on TM1 ExcelServicePortNumber parameter in the web.config file)
Your assistance on this matter shall be highly appreciated
Thanks & Regards,
Ashwin
TM1 Ports Inbound / Outbound Configurations
ashwinchitkara
- Version: 9.5
- Excel Version: 2003
- Visio-Basic Server Layout.pdf
- Page 1 Basic setup Page 2 Port details
- (37.87 KiB) Downloaded 609 times
